L76 from a G8 - anything to consider?
Is there any reason this wouldn't be a good candidate for a swap project? I know I'll have to change the oil pan but I believe the front accessory drive will work. And while I know it's possible to eliminate DOD, I've read there are now custom cam grinds available that will develop good power and maintain the DOD.
Anything I'm missing?
TIA.
Tipsy
There are lots of complaints about the DOD lifters failing, so eliminating it altogether may not be a bad idea. If it has VVT, be sure to find out which of the two styles of phasers is on it, which is important when ordering the cam.
So, AFM/DOD delete will be required to install a more aggressive cam, which is a no brainer with this engine, in my opinion.
Tipsy
