ls3 timing marks ?s
Old Sep 23, 2013 | 05:55 PM
allan808's Avatar
Default ls3 timing marks ?s
When installing a timing chain the cam gear dot is at 6 oclock and crank gear is at 12 oclock,is that correct?
im doing a 24x conversion if that helps.im little confused on the direction my book gives, it says some engines have timing gear at 12 oclock & crank gear at 6 oclock? also How do you find top dead center on #1?
Old Sep 23, 2013 | 06:12 PM
KCS's Avatar
KCS
Moderator
Cam gear should be at 6, crank gear at 12. This is known as "dot to dot", respectively.
There are several ways to find TDC. You can use a piston stop in the spark plug hole if you have the heads installed already, if not a deck bridge indicator will work as well. For detailed instructions, look up Comp Cams' website. They have a pretty good how to.
Old Sep 23, 2013 | 06:50 PM
allan808's Avatar
Thank you!
