Confused about LS7 heads
I have acquired an LS7 out of a Z06 with about 6000 miles on it. I'm planning to go through it thoroughly before I install it, but I'm confused as to whether I should:
1. send the factory heads to WCCH for guides and porting. If yes, do I let them put in Stainless exhaust valves, or pay for Titanium?
2. Buy the PRC heads from Texas Speed. If this route is chosen, do I get the 265 or 285 version. I am not planning to change the cam from stock.
I am planning to use a FAST 102mm intake matched to a Motec M800 ECU.
Thanks for any ideas on either 1 or 2 - and anything else the group recommends.
AG
- You can send your heads to Texas Speed and have them run either the 265 or 285 porting program on them. The 285's could be used with bigger cams on a 427, or on
larger cubes like a 434 or 440.
- Reher Morrison has a program. Call Darin Morgan there. Great great guy.
Also, the titanium v SS exhaust valves is a personal preference, but from all the porters I've talked to, they've told me the TI exhaust valves aren't really needed for a street car.
AI also does LS7 heads and that's who LG uses on their packages. They've made like 660rwhp with the stock LS7 manifold with those in a 454.
