LQ4 No Oil Pressure
First start up i didnt have any oil pressure so i shut it off.
Changed the OPSU thinking i broke it, still no pressure.
Figured that the LQ oil pump was bad so i pulled it off and replaced it with a mellings standard pump, made sure the o-ring wasnt crushed or damaged and was installed correctly. I packed the oil pump with assymbly lube to prime it.
Started it up and STILL no oil pressure. I hooked up a mechanical gauge and oil didnt even flow into the tube.. Pulled the oil filter and started the car and oil didnt even come out..
the barbell galley plug in the back of the block is there.
Any sudgestions? only other thing we can think of is maybe my oil pickup tube is busted somewhere.
Double check the depth of the pickup VS. oilcan. I hope you PRELUBED the engine prior to starting it. Good luck.
I haven't let it run long honestly 4seonnds is the Max it has ever ran. O-ring is probably seated
Reason why i posted this is because i have searched.. why doesnt the oil pump come with instuctuion about shimming, the only thing i have ever heard people shim is the relief spring. i dont want to tamper with the pump and void my warrenty.. my stock pump wasnt shimmed so this one should be shimmed since its the exact same model number. since you seem so knowledgeable about shimming, could you share your wealth of knowledge?
Again. try a SEARCH
https://ls1tech.com/forums/generatio...questions.html
I hope your having better luck than I am Lol. I am going to double check O ring/pick up,gallery plugs oil pump etc? thanks guys! Last edited by strmachinist; Feb 1, 2014 at 07:13 PM.
When we go to check the oil pickup we are going to replace the bearings as well :/ so if anyone knows a cheap place to get those tri-coated main and rod bearings or offers a military discount it would be greatly appreciated
