oil pump question
Old Feb 6, 2014 | 05:40 PM
jerrya's Avatar
Default oil pump question
I am swapping a L96 into my Beaumont, reading lots to figure this out. I have seen lots of talk of ported oil pumps, hv pumps etc.. Are the oem pumps not up to the task?
Old Feb 6, 2014 | 07:03 PM
FastKat's Avatar
It depends. I think a stock oil pump is fine for a stock engine. It's probably also good for mild performance engines.
There's one place that extra oil pressure will be a big help. If you have a rebuilt performance engine, you might not know exactly what your bearing clearances are. If your clearances are on the loose side, extra oil volume (leading to higher pressure) will be a BIG help and hide/eliminate a lot of the problems you would otherwise encounter with loose bearing clearances.
How much extra you might need is often debated. You can always run more volume/pressure, but in theory it will use more HP than a stock pump. A ported LS1 pump is probably a good pump for most aftermarket performance engines. The pumps found in Gen4 AFM/DoD vehicles move a lot of oil and are probably overkill, though sometimes people still run them.
