4.8 to 6.0 Silverado
Old Mar 20, 2014 | 11:02 AM
TAPyvehc93's Avatar
Default 4.8 to 6.0 Silverado
Couple questions for you all. I got a 4.8 L20 flex fuel Silverado and was wanting to know what all is need to go to a LY6 6.0. I was under the impression that all i needed was the LY6 long block, and that my intake/fuel system/accesories from my 4.8 would swap over. But now i have been told that my 4.8 intake wont work with the l92 heads that come with the LY6. Its that true? Also what about the fuel pump/injectors/rails. I heard that the 4.8-6.0 injectors are all the same, although mines a flex fuel so the 4.8 injectors should be a little stronger than the stock LY6 injectors right? I figured the flex fuel pump would be fine also, but what do i know? And i am assuming the accessories should bolt up just fine. Am i missing anything. Also, anyone know if the lq4 would be a plug and play in a nnbs Silverado like the lye is?
