heads/cam for LS3
Keep those, maybe get them ported, and get a matching cam. If you keep the compression up and cam relatively small, it should not affect your mileage too much if at all.
For me, heads and a small cam only lost 1-2mpg in town and on the highway it's about the same.
A cam swap, on the other hand, can give you some serious gains ! Just be careful not to over cam it. Make sure the rest of the drive train is matched to the cams working RPM range and you will be very happy.
