help building oil psi
junkyard 5.3l with xxx unkown miles
torker v2 cam
all i did was pull the pan windage tray and pickup tube out to clean (sludgey) and pull the front cover to do a cam swap and this thing wont build any oil psi :/
it acts like its trying to i need some help
i made sure that the o ring on the pickup tube didnt rolll or anything i lubed it good
you can rev it to 2000 rpm and it will build like 25-30 but when you let it idle down it goes back to zero.......
i need some thoughts from you guys
