timing chain?
Old Jun 14, 2014 | 01:13 PM
kill4thril's Avatar
Default timing chain?
just looking to get your guys thoughts on using a .005 smaller timing chain when having a block line honed? im trying to brake in to the 700+hp range with the engine and was just wondering if it was worth it or not to get one or should i get a timing chain set that has an adjustable cam sprocket? i cant fined any shorter kits that come with the adjustable cam gear.
thanks for the help
,Jesse
Old Jun 15, 2014 | 11:17 AM
FastKat's Avatar
For a frame of reference, .005 is about the width of one or two human hairs. That's a really small number - not sure if it's worth it or not.
Old Jun 15, 2014 | 11:54 AM
1989GTA's Avatar
At .005" I would not worry about it.
Old Jun 16, 2014 | 08:18 PM
kill4thril's Avatar
so what timing chain kit would you guys recomend?
Old Jun 16, 2014 | 09:26 PM
A.R. Shale Targa's Avatar
http://www.progearweb.com/4000/pg4210.htm
Less than a Franklin $$$$
Old Jun 16, 2014 | 11:29 PM
FastKat's Avatar
I would just get stock gears (new or used) and a new OE chain. I've run used chains on both of my engine builds.
Old Jun 16, 2014 | 11:31 PM
JakeFusion's Avatar
Super Hulk Smash
Cloyes with the C5R chain. Get billet gears with adjustability and run a stout single chain.
I have had good success with the Rollmaster "Gold" double roller. It is a more affordable piece but requires more patience and labor to install.
Old Jun 17, 2014 | 12:11 AM
COSPEED2's Avatar
LS1Tech Sponsor
http://www.coloradospeed.com/cloyes-...2-p-20505.html
http://www.coloradospeed.com/cloyes-...2-p-14256.html
Or we have just the "Z' (c5r) chain for $168.
http://www.coloradospeed.com/cloyes-...s-p-33131.html
The best thing about every cloyes set is, they are hand matched. Meaning someone makes sure the marks line up correctly on every set before they are put in the box. I am not sure any other company does that period.
 Michael S. Palmer
