Hesitation at low rpm. 05 GTO LS2
I have a Pontiac GTO with the 6.0 LS2.
It has a Comp Cam ( ill post the specs later dont recall them offhand), a cai, LT Headers, full exhaust, anda TBS.
Heres the situation.
When the car is in park and you go to rev it up from idle it has quite a noticeable hesitation when you hit the gas. After it makes its way though that lil spurt it revs up fine. It also does the same thing when you go to launch. (Did it to me launching at the track) Almost like it has a retard set into it. And its a consistent happening not an on and off occurence.
Thanks for any help you can provide.
Chris
Did it just start doing this after you changed the air filter?
You need to check for air leaks after the MAF. If this is a relatively stock car, I would say the engine is either sucking in unmetered air, or your tune scaled the MAF tables where it shouldn't have.
Oh, and check for exhaust leaks from the header to head flange all the way down about a foot after the front o2 sensors. The system will believe it's lean if outside air makes it to the o2 sensor. As a consequence, it may actually cause an over rich condition even though it's measuring lean.
Does that make sense?
