My LS7 442 Build
Old Mar 16, 2015 | 08:11 AM
CAMSTER's Avatar
Originally Posted by Martin@Tick
He'll be using Morel 5425's which is a .842" body Ultra Pro high pressure pin fed oiling roller lifter.
Glad to see the cam came in smoothly! Looks great!
This cam is actually IMO fairly mild for a solid roller camshaft. Lash takes away a large amount of low lift duration. Consequently the majority of the overlap period in street/strip camshafts occurs at low lift.
The cam should drive excellently, but have a mean idle at the same time...just what Malachi wanted.
With how well the heads flow above .600" lift, this cam will be able to take advantage of every bit of that and really make some great power on the rollers. I expect a 6500-6700rpm power peak and for it to carry 7200-7400rpm.
Thanks Martin, I noticed you carry both Morel and Comp Cams Elite solid roller lifters, not familiar with the Morel 5425 but familiar with the elite race, which one would you say is best, and are the Morels 5425 lighter than the Elite, I must buy a set in another week or so for my new max effort solid roller cam stock block LS3, thanks kindly, David.
Old Mar 20, 2015 | 01:43 PM
Sales@Tick's Avatar
David,
I honestly do not know how much the Morel lifters weigh. I do not put much if any stock in weight on the push rod/lifter side of the valve train. It has little to no effect on valve train control.
I put all my efforts into making the push rod/cam/lifter side of the valve train as stiff and as rigid as possible thus transferring as much effective tappet motion to the valve.
I like to concentrate my efforts in weight savings over the valve itself as that is where it will pay off the most.
I really like Morel lifters and use them almost exclusively in all of our builds.
Old May 21, 2015 | 04:53 PM
SHovV's Avatar
Small update. Frankenstein is finally done with everything, so I'm over here like
Heads, ported FAST 102mm and Crowers should be here early next week. All that is left to get are headers, pushrods, timing chain and lifters.
Heres' a few teaser shots of the head work FRH sent to me.
I'll get more pictures of everything once it all arrives.
Also, my custom plates came in. I think it'll fit the personality of the car perfectly, as well as describe my love of metal and punk music. A couple of tweaks and they'll be perfect.
Before tweak :
After tweak :
Also thinking of adding the Misfits skull / Pantera logo in place of the star and Texas symbol
Until next time...
Old May 21, 2015 | 09:11 PM
WVhuggerSS's Avatar
This build is strait gangster! Id love to have that ls7, that thing is going to be nasty! How much did it cost for the heads to be milled down for the crowler rockers, I really like those.
Old May 23, 2015 | 01:40 AM
SHovV's Avatar
Invoice shows 350$ to machine the pedestals down for the Crowers, which actually had to be machined to a specific height based on my cam specs according to Crowers instructions.
Old May 23, 2015 | 12:38 PM
Jimbo1367's Avatar
Gonna be bad azz though!!!
Old May 29, 2015 | 12:15 AM
SHovV's Avatar
Thanks guys. Heads, Crowers and FAST came in from Frankenstein on Tuesday. Here's a bunch of cell phone pics. I'll get better pics this weekend.
Size:  106.1 KBName:  IMG_4932_zpsrbbjcsba.jpg
Old May 29, 2015 | 09:04 AM
tadams72's Avatar
Looking good! Love those Crowers. I drive by their facility about once a week and every time I get visions of those damn rockers...
Old May 29, 2015 | 04:25 PM
Sales@Tick's Avatar
Looks great Malachi!
Old Sep 21, 2015 | 12:31 AM
SHovV's Avatar
Well, not much of an update, but after spending what seems like endless hours researching valvetrain geometry, talking to the people I got my parts from, I'm happy to say my valve train is setup! I get the best geometry angles and wipe pattern using one Crower supplied .045 shim for the rocker base.
Pushrods will come from Manton. Series 5 7/16 x .120 at 8.600 is what they'll be.
Got all my clutch measurements while everything is blown apart also. Everything is golden there as well. I completely disassembled the slave to thoroughly clean it as it been 40k miles with the stock fluid. Yuk. I'll be replacing that shitty little plastic bearing support with Monsters billet piece.
All I need now is to drill and tap the rear steam ports, get a couple gaskets and clearance the heads for the pushrods and it'll drop this bad boy in the car.
Shouldn't be too much longer now!
Old Sep 21, 2015 | 05:44 PM
slogo's Avatar
Looking good, looking forward for a video.
Old Sep 27, 2015 | 10:09 PM
  #32
Strokedcamaroz28's Avatar
in for results.. very similar set up to mine, you did go solid roller and i went hydraulic but cam specs are almost dead on.. think i have a little more compression and not sure how our heads compare to each other.... def in for results.... did you consider the holly high rise? i got rid of my fast for the holly... just my .02
Old Sep 27, 2015 | 11:25 PM
  #33
SHovV's Avatar
Na, I didn't consider it at all really cause I'm not at the point where I want to cut my hood up just yet.
Now to mention when and if I ever do decide to get an aluminum intake.....
Ugh, it'd be hard to make up my mind lol
Do I get a FRH ported Holley, a single plane?
Initially I'd like to run a single plane with a carb style tb, but no one makes dbw setup. I'd have to do like Ryan Stevens did and make a bracket and linkage for the dbw motor to the carb tb.
Decisions decisions.....
Old Oct 15, 2015 | 07:43 AM
  #34
SHovV's Avatar
I've finished up all the small tasks finally. The motor is jus about ready to be dropped in. Only thing I need is cover gaskets, billet tob support and the C7R chain.
Clutch / slave measurements are good. Right at .100 or so. I also cleaned and flushed the 40k mile nasty fluid out of the master, slave and lines. This should help minimize any potential issues there.
Next was p/v. I have clearance for days there. It was somewhere .240+ for both. The piston only stick out .375 at bdc.
Clearanced the pushrod holes so I can run 7/16 columns from Manton. Pretty sure I'd have room for 1/2 rods, but that won't be necessary.
Here's some before and afters. Just have to tidy them up a little more.
Old Oct 15, 2015 | 07:49 AM
  #35
SHovV's Avatar
Here's something I found very interesting. The rear steam ports on the LS7 heads are actually riveted closed. When I was getting ready to drill the port out I noticed they looked plugged up. Took a small punch to the under side of the head and knocked the plugs out. Drilled and tapped them for -4.
Old Oct 15, 2015 | 09:43 AM
  #36
speedtigger's Avatar
Old School Heavy
Damn 7/16 pushrods. Well, that will not be a weak area. LOL Awesome build. I am looking forward to the results.
Old Oct 15, 2015 | 12:27 PM
  #37
DavidBoren's Avatar
All of this is pure sex. I love all of it.
The vanity plate is F'ing awesome. The engine is a work of art. This is just so rad. And the fact that it's going to be cruising around blasting **** like the misfits and slayer makes me smile, lots.
Old Oct 15, 2015 | 09:57 PM
  #38
SHovV's Avatar
I figure no point in going solid roller with out making it as flex free and consistent as possible.
Only real heavy metal and punk for this dude lol. Mixed with some old school rap.
Thanks guys
Old Oct 16, 2015 | 09:50 AM
  #39
Sales@Tick's Avatar
With such a long push rod, it's great to see that Malachi is using a 7/16" push rod. I have always been an advocate that as an engine builder or even just as an enthusiast, that you should always do whatever it takes to fit the biggest diameter push rod you possibly can fit in the push rod passage.
Old Oct 16, 2015 | 12:18 PM
  #40
SHovV's Avatar
So 1/2 rods? Lol
