Callies Dragon Slayer
Old Jul 26, 2014 | 11:39 PM
ZeOhhSix's Avatar
Default Callies Dragon Slayer
looking to build a 1500HP C6Z using an 427CID and F1X with ton of nitrous, all I need to know whats the range of Dragon Slayer is it a good choice to go with or should I get a built Crankshaft as well.
best,
Mubarak.
Old Aug 1, 2014 | 05:22 PM
mebuildit's Avatar
Why not go with their Magnum series crank?
Old Aug 2, 2014 | 10:00 AM
totalchaos's Avatar
x2....
Old Aug 12, 2014 | 09:12 AM
Nuclear Banana's Avatar
I think the Slayer stops around 900hp. You will probably need a Magnum. I have a Magnum in my Big block that makes about 1500hp, but a big block crank is a different animal and pretty stocky.
Next choice would be to start looking at billet cranks at the HP range.
Old Aug 12, 2014 | 03:20 PM
toytech93's Avatar
I was told Callies rates their cranks:
Compstar -900hp
Dragon slayer -1500hp
Magnum -2000hp
Old Aug 12, 2014 | 05:35 PM
CBM Motorsports's Avatar
For the abuse of nitrous, I would go with the Magnum for the safety. The Dragon Slayer will hold to 1500 HP but for the cost difference vs. piece of mind, I would go Magnum.
Old Aug 12, 2014 | 07:44 PM
Ari G's Avatar
You need to get a center counterweight crank and double keyed snout to handle all that power and load
