LS3 Exhaust Port Length
Dyno Junkie, Since I'm bothering to use pipemax to calculate ideal header dimensions, I didn't want to then build them to different dimensions because I didn't have an accurate exhaust port length. Pipemax gives you the total length required for the wave tuning based on exhaust closing point of the cam and a bunch of other variables, but the length it gives you is supposed to represent the distance from the valve to either the step or the distal merge point of the collector; so obviously you have to subtract the length of the exhaust port when deciding how long to make the primaries.
