No oil pressure (ls7)
Replaced the Oil Pressure Sending Unit and added an analog gauge as backup thinking it was the issue.....STILL LOOSING PRESSURE!
At idle and 195-200deg. Pressure is fine BUT when loading the engine at 3500-5500 rpm the pressure is lost... all of it! If I shut the engine off and wait 5-10min. I get my pressure back at idle.... totally crazy!!
I was told to add some oil and watch the level in the oil tank. WELL..WELL... When it drops pressure I noticed that there is no oil in the tank...Could it be a bad oil pump? Dipstick was dry!!!! Where did the oil go?
Thank You
