LS3 Based 350
Old Dec 1, 2014 | 10:14 AM
compted's Avatar
Default LS3 Based 350
I was wondering if anyone had bored a LS3 to 4.09" and destroked it to 3.325"?
Old Dec 6, 2014 | 06:47 AM
96 Comp T/A's Avatar
Not a lot of folks destroking engines unless you are trying to reach a specific cubic inch limitation of a sanctioning body. Bigger is better.
Old Dec 8, 2014 | 08:09 PM
compted's Avatar
Default Revving Capability increase?
By doing this do I not gain a boost in engine speed capability? Or is it too minimal to consider?
Old Dec 8, 2014 | 10:06 PM
You gain back some headroom in piston speed, but that's not really a great reason to do it, because you aren't any where close to critical with a stock stroke crankshaft anyway. I wouldn't consider decreasing stroke to be a boost in RPM capability, but rather a requirement of increased cycling speed to do the same amount of work (pump air) that could be done with a larger displacement. Friction increases exponentially with the RPM increase so it rarely pays off. If you are displacement limited by class rules, it can be a totally different ball game.
