help with my valve train 408LS3
Old Jan 8, 2015 | 10:29 PM
N/A86's Avatar
Originally Posted by TurboBuick6
My car is a summer DD. 60 miles a day and I run it hard to 6,800 every time it's on the road. That's at .650 lift too.
And what do you run for valves ect?
Old Jan 8, 2015 | 10:33 PM
N/A86's Avatar
Also I see you suggested injectors, I'm really hoping to get away with the stock ls3's.. I know I'll be pushing them but I'd like to drive it this summer and that is an easier change down the road than internals, Also I'm only running a single in tank 255 6an feed and return and a vette regulator/ filter so Ill prob be close to the limits on the whole fuel side
TurboBuick6's Avatar
Z06 valves from the 243 heads.
Old Jan 8, 2015 | 10:36 PM
N/A86's Avatar
And I've been told the 11.5-11.7 for comp may be too much for pump gas... Livernoise said the had the pistons custom made for that comp as I said I'd like to get the most on pump as I can, However in there specs they sent me they claim to use a off the shelf wisceo and we did our math and found I should be closer to 10.5-10.7 soooo don't know if livernoise slipped up or if they sent me the wrong piston specs
Old Jan 8, 2015 | 10:41 PM
You need to know what the static compression is. Don't worry if it's high. You can get a custom cam to drop the dynamic compression as that is what really counts.
Old Jan 8, 2015 | 10:49 PM
N/A86's Avatar
Yeah I'll have to give them a call tomorrow, Thanks for all your input I appreciate it
Old Jan 8, 2015 | 11:35 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Just give us a yell! We stock a nice prc hollow stem ls3 valve, and can put you togeyher a package that'll round out your combo nicely!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
