Timing chain damper install
Old Feb 5, 2015 | 12:38 PM
69gto96z's Avatar
Default Timing chain damper install
Getting ready to install a ls2 timing set on a ls1. I bought the ls6 damper from katech. Reason i am posting in here is because i know a lot of ls2/3 guys are using dampers. Through my research, i have found to torque the bolts to 18 ft/lb. Can the damper be installed after the chain and timing set are already in, or does it need to go on before? Mine won't be here until tomorrow, and i would like to get the timing set on today to move forward with other things on the build. Any info is appreciated. Thanks,
Old Feb 5, 2015 | 06:51 PM
6togo's Avatar
It will fit in after the chain and gears are on no problem! $94 for a damper OUCH!
The LS2 version not fit it's like $16 from GM?
Old Feb 5, 2015 | 09:15 PM
69gto96z's Avatar
Awesome, looking at pics it looked like it would. Yes it was pretty pricey! LS2 has a 1.7" bolt spacing, ls1 has a 2.1" spacing. Trick flow sells an adapter set up to fit the ls2 on a ls1 block for about 40 bucks, but summit said they were on manufacturing backorder! Needed it by this weekend so i had no choice but to get the ls6 one!
Old Feb 7, 2015 | 08:59 PM
JakeFusion's Avatar
Super Hulk Smash
I have the Katech in mine. I installed before, but I think there's room. My double roller didn't have any slack. If you're using an LS2 chain or something, you should have no problem.
Old Feb 7, 2015 | 09:53 PM
6togo's Avatar
Mine has a double roller and it went right in that is after i removed the oil pump!
