Looking for help figuring out 11:1
Old Feb 11, 2015 | 02:12 PM
edge04's Avatar
Default Looking for help figuring out 11:1
I have a stock ls2 out of a 2006 vette. I will be running GM LS3 heads that are 69cc and would like to be 11:1 static compression without changing pistons.
I believe stock was 10.9 with the stock ls2 heads and stock head gasket of .051 thickness.
So with the bigger chambers what head gasket would get me there?
thanks
Old Feb 11, 2015 | 05:41 PM
A.R. Shale Targa's Avatar
you are adding 4.5cc of chamber volume, so there is no way you can now thin the head gaskets enough to get that back without the pistons crashing into the head. With the large 2.165" intake valves, milling the heads reduces the size of the intake lobe (cam) that will fit without hitting the piston.
Old Feb 11, 2015 | 08:29 PM
MuhThugga's Avatar
You're going to need to mill the heads .030" to get there. Not a big deal, but you will need to verify valve clearances with whatever cam you decide to run.
Old Feb 12, 2015 | 10:40 AM
edge04's Avatar
the stock ls2 head gasket is .051 correct? running that with doing no milling of the head would put me where? assuming around 10.5? thanks
Old Feb 12, 2015 | 01:53 PM
edge04's Avatar
checked with my cam builder. only option I have without new pistons is to leave the heads as is and run a .040 gasket which would put me around 10.7
Old Feb 12, 2015 | 04:24 PM
MuhThugga's Avatar
You would be at 10.5, I believe. Maybe even a little under.
And bullshit that you'll need new pistons. There are plenty of people who milled those heads .030" with stock gaskets and had a cam made that didn't require new pistons.
Old Feb 12, 2015 | 05:40 PM
running a .040" gasket and milling the heads .010" I calculated about 10.85-10.9 range compression ratio, depending if you figure a bit of primary ring-up-volume around the piston.
I'd stay short on the intake lobe to not cause PTV clearance issues. The Brian Tooley stage one LS3 cam would be my choice or something similar.
EPS and Tick can also get you a nice custom camshaft
Old Feb 12, 2015 | 06:09 PM
Zfan's Avatar
Fly cut pistons?
Old Feb 12, 2015 | 08:46 PM
edge04's Avatar
Tick built my cam and gave the advice to just run the .040 gasket and leave the heads as is. martin did say fly cut the pistons but I'm not pulling the short block yet.
Old Feb 12, 2015 | 09:03 PM
MuhThugga's Avatar
You can flycut in the car. It isn't a big issue. Tape and the vacuum are your friends.
Old Feb 13, 2015 | 11:15 AM
v8pwr's Avatar
I would suggest that you stick with the stock 243 heads and spend your money elsewhere or port the stock heads.
Old Feb 13, 2015 | 11:27 AM
edge04's Avatar
already have the heads. I'm going from FI to NA, down from 750 horse to 450-500 with a basic set up
cam, heads, stock ported intake, long tube headers, CAI.
Old Feb 13, 2015 | 11:43 AM
redtan's Avatar
Did you mean the exhaust lobe of the cam? Because the intake duration and lift of the cam lobes has almost nothing to do with PTV (except in very extreme cases where you have a huge lift and fast ramp rates). The intake valve is pretty much shut or just getting of its seat when the piston is at TDC when PTV is most needed. By the time the valve starts opening and is at full lift, the piston is looong gone down the cylinder.
Now the exhaust valve is the one that's open fully as the piston is rushing towards it on the exhaust stroke, so that's the one that's going to run into PTV issues with too much duration and lift.
Old Feb 14, 2015 | 02:56 PM
edge04's Avatar
so here is my cam specs
INT 279
Ext 297
227/243 @ 50
114
valve lift 632/627
Old Feb 14, 2015 | 03:54 PM
INT 279
Ext 297
227/243 @ 50
114
valve lift 632/627
Martin is correct....do not mill if you are using the .040 gasket
uncut LS3 heads can usually only safely fit a 230-232 duration intake lobe
I know people have fit larger but have knowingly accepted the consequences for running tighter than .060"/.080" PTV
My thoughts for your combo was to run the thinner gasket for tight quench which helps when you can't have the desired compression ratio, a clean up cut of .010" on the heads just to try to get you back to factory LS2 compression rating and then run a 224 intake lobe as the huge LS3 runner doesn't need a ton of duration to get a bunch of air in there.
Since you already have the 227 cam and Martin knows exactly what will fit safely and not, just run the 040 gasket and double check the clearances as I suspect both valves will be quite close.
Old Feb 14, 2015 | 04:03 PM
Originally Posted by redtan
The intake duration and lift of the cam has EVERYTHING to do with PTV (LS camshafts have a huge lift and fast ramp rates). The intake valve is pretty much getting off its seat when the piston is at 7 degrees ATDC and PTV is most needed. By the time the valve is at full lift, the piston is looong gone down the cylinder.
Now the exhaust valve is the one that's open fully as the piston is rushing towards it on the exhaust stroke, so that's ALSO the one that's going to run into PTV issues 7 degrees BTDC with too much duration and lift.
FIXED FOR YA.....
Old Feb 14, 2015 | 04:04 PM
edge04's Avatar
going to check the clearances. according to the machine shop there are a few scratches on the head surface so they want to clean them. I told them I can't go .010 not even .005. Wonder if I should just leave them
Old Feb 14, 2015 | 04:19 PM
Martin would be the one to tell ya as he has installed so many different cams in so many different LS block, piston, head combos.
I'd even bet that he can tell you within .005" of what your clearances will be depending on your valve springs, timing chain, and whether or not the heads have had a valve job or not.
Old Feb 14, 2015 | 04:48 PM
edge04's Avatar
here's one for you guys
on my previous build I hade different size pushrods from driver side to passenger. 7.40 and7.325. Same heads, same head gaskets, etc. Had the heads checked and machine shop says they are identical and valve stem height is the same as well.
to the best of my knowledge the short block has never been touched. why the heck difference?? cam profile? why?
Old Feb 14, 2015 | 05:33 PM
crappy block casting
cam tunnel not centered over the crankshaft which makes one set of lifters sit higher relative to the deck height
