Measuring pushrods
Old Mar 15, 2015 | 12:01 PM
maroonls1z's Avatar
Default Measuring pushrods
So I used a comp cams pushrod measurer and have all my values and I'm about to order my pushrods. What do you use to confirm how long the pushrods are when you receive them? Also as a side note, I think the lifter cup in my rockers are a little different from one to the next causing my measurements to vary by about 0.02. Normally I wouldn't think that an issue but I'm using lifters with only 0.058 travel
Old Mar 15, 2015 | 10:48 PM
CAMSTER's Avatar
I guess you will use the measurer^^^ or just put them on if it works is good.
I use a 12 inch dial caliper.
Old Mar 16, 2015 | 03:55 AM
maroonls1z's Avatar
Okay so a 8" dial caliper to confirm when I get them from manton, thanks
