Question about LS Series heads
I just got done with a production run of Throttle cable brackets that uses the factory mounting holes on LS1/2/3/6/L76 intake manifolds. These will allow you to use a cable throttle body on any LS series intake and Im curious if they can be used with the LS7 intake manifold too?
I would also like to say that they are $25 shipped,powder coated to match the intake manifold, Fit under the coil covers, Fit over sized and stock injectors and accept any aftermarket throttle cable. As far as Im concerned these are the only brackets that do all of that and are by far the cheapest!
