Need help building a 5.3
Old Apr 13, 2015 | 11:19 PM
RiskyBusiness32's Avatar
Default Need help building a 5.3
Alright guys I'm new to the LS world I have owned these engines but never took one apart. I'm very familiar with the older sbc engines. So to start I have a 1987 c10 2wd swb originally 350/700r4. But I have taken the motor out and have now purchased a lm7 5.3 and a 4l60e trans I have done my research but still have a couple questions.. I plan to build a fuel injected turbo motor and I would like to run the stock bottom end with a Texas speed 228r cam with 114 lsa and use ls6 heads and a fast lsx intake. So my questions are is the 228r cam a good cam for a turbo? Are ls6 heads good for the turbo? And what oil pump should I run? Also I plan on running a 3200 yank stall with 373 gears anyone have any input on this or any tips?
Old Apr 13, 2015 | 11:21 PM
Also what's the best wiring harness? Should I have one made or but one?
Old Apr 23, 2015 | 05:49 AM
gagliano7's Avatar
http://www.bp-automotive.com/ for your wiring.
Old Apr 24, 2015 | 04:04 AM
Gbody6liter's Avatar
I vote C5 Z06 cam. It's cheap and makes good power with boost.
Old May 21, 2015 | 11:13 AM
cr250r's Avatar
i'd run the stock cam man the've made 5-600 at the wheels and your going to blow the 4l60e up if you go anymore if you had an 80e i'd recommend martin@ tick performance or lil john motorsports
Old May 21, 2015 | 12:03 PM
KCS's Avatar
KCS
Moderator
I would probably swap the 243 heads for some 317 heads to lower the compression ratio.
