LS3 PCV delete with oil mist
Old May 22, 2015 | 07:31 PM
redbird555's Avatar
and yes the pcv valve is basically a check valve...the newer gm design is actually just a hollow plug with a small hole in it
Old May 22, 2015 | 07:57 PM
bunkerbuster's Avatar
Originally Posted by redbird555
you need a pcv valve between the valve cover and the catch can otherwise it looks ok
I meant to edit, the pcv valve is basically embedded in the driver side nipple, and the aluminum nipple piece pops right out. Checked 1 way action by blowing both ways.
Should I consider putting check valve on fresh air blow? So that it can only blow fresh air rather than diffuse oil mist into the TB?
