Need Help with Bank 1 and Tapping Noise
Old May 24, 2015 | 01:37 PM
waderaces427's Avatar
Default Need Help with Bank 1 and Tapping Noise
Trying to dial in an LS3 crate engine. Used the infrared to take temps and the pass side avg 490 degrees vs the driver side is 400 with cylinder 5 at 335. Also, have a tapping noise at approx 1/2 speed. Maybe lifter the engine has less than 200 miles on it and has not been beat on. I have read all the threads via search regarding misfires at idle and under load and not sure what else to do. Here's what I have done so far and no mil light...
New plugs, switched wires, coil packs, o2 sensors, checked for vacuum leaks, checked for exhaust leaks, switched fuel rail around, checked rocker arms and pushrods on cylinder 5
Thanks for watching video....
Old May 24, 2015 | 06:23 PM
CAMSTER's Avatar
Sounds like an exhaust leak to me check if all bolts are tight.
Old May 24, 2015 | 08:49 PM
Thanks for the reply. I checked again which was the third time checking and there was a small leak at the manifold to downpipe connection! I will have to drive to see if the misfire is gone after resetting the LTFT. Still not sure why there is such a big difference in heat between Bank 1 vs. Bank 2 with infrared gun.....
Old May 25, 2015 | 07:32 AM
CAMSTER's Avatar
Heat difference between banks in idle will be quite different under boost.
When you change your spark plugs and ran fuel injector cleaner check heat again.
Old May 25, 2015 | 09:17 AM
dw456post's Avatar
Link bar lifters? They make a little more noise.
Not enough lifter preload?
The laser heat guns need to read the exact same spot and the same angle on each exhaust pipe to get a good reading----at least that is the way mine reads.
