advice needed
Old May 28, 2015 | 07:23 PM
showdog75's Avatar
Default advice needed
I've got a ls2 I bought to put in my 63 chevyII wagon. The engine has been and will be sitting for several months longer while I continue to gather parts for the swap. I pulled the plugs and spayed some Stabil fogging oil in the cylinders and while spraying the last cylinder the red straw shot straight into the cylinder. I haven't been able to get it out yet and I really hope I don't have to pull the head. Any suggestions? What's the chance that it would pass through the head without issue if left in the cylinder?
Old May 28, 2015 | 07:58 PM
brandon6.0's Avatar
Try bringing the motor up on tdc for that cylinder. The compression should try and blow it out of the plug hole.
Old May 28, 2015 | 08:10 PM
MuhThugga's Avatar
Top dead center + long needle nose pliers + patience
