Picked up a LY6. Should I play with the compression or no?
Now here is the question. Should I replace the LQ4 pistons or go to flat top LQ9 pistons?
These are the measurements I am using for CR.
Cylinder Head Volume = 70cc
Piston Head Volume: LQ4=6(ish)cc LQ9=0cc
Gasket Thickness = .051
Gasket Bore = 4.100
Cylinder Bore = 4.030
Deck Clearance = -.005
Stroke = 3.622
Compression LQ4 = 9.8 LQ9 = 10.5
Piston Compression Height = 1.326
Deck Clearance: 9.240-6.098-(3.622/2)-1.326 = -.005
Replacement pistons are almost the exact same cost so it comes down to the final static CR. Is it worth it to get the extra .7? I am able to reduce the dynamic CR with the camshaft that Texas speed specs out.
Curious if I will lose that much power versus possibly having to run a higher octane fuel.
What are your thoughts?
Thanks
Shane
I would make sure you ptv clearance is going to be ok right now with the cam you're choosing and then see what you can mill off the heads. Whatever you deem that to be I would then go .015 less and run a .040 cometic gasket. That will achieve the same compression gain as that last .015 on the head but will lower quench which will help fight detonation and allow you to run more timing with the increased compression
http://www.ebay.com/itm/02-07-Chevy-GMC-Cadillac-6-0L-V8-LQ9-VORTEC-N-8-Flat-Top-Pistons-Moly-Rings-/121611122870?hash=item1c509678b6&vxp=mtr
One thing I just noticed is that they are cast pistons and the factories are Hypereutectics. Should this be an issue?
I spoke to texas speed a couple months ago and these are the specs they suggested for the cam they were going to grind for me.
227/235
.61"/.621"
109+2
I will call back and have them confirm once I get the rest of the engine figured out. The crank is within spec but my machinist said he is going to polish it. Rods are fine. So I will have him rebalance the whole assembly. I was also thinking about just running an LS3 or L76 factory intake with a cable throttle body.
Could you guys give me any idea of rough HP numbers? I would thinking 600hp should be pretty close with the LQ9 pistons.
Thanks for the input!
Shane
