Morel lifters
Old Jul 6, 2015 | 01:34 AM
03EBZ06's Avatar
Originally Posted by chuxdelux
I've looked at Iskys as well, from the little that I've read online they are particular to the cleanliness of oil. What has your experience been? I was told that I should run the 375RHM.
I have not had them long, so no comment on how durable yet, but I keep my oil clean. Isky has been around a long time and they make excellent products. My experience to date is they work well. Also, that is the same part number I have.
Old Jul 6, 2015 | 03:22 AM
SHovV's Avatar
Originally Posted by Millenium Z06
I would avoid Morel, I bought a set of Morel 5274 LS Pro Series lifters and they failed almost immediately and Morel has no warranty once installed, nothing at all (THESE LIFTERS ARE SOLD AS IS WITH NO TYPE OF WARRNTY OR EXCHANGE OFFERED ONCE THEY'RE INSTALLED).
Had to buy a second set of lifters, went with Lunati Hydraulic 72532 and they have a 90 day warranty but so far they've been fine.
How exact did your lifters fail?
Old Jul 6, 2015 | 08:52 AM
Fraser588's Avatar
Specs on engine are:
ERL 434 w/ Swain-tech gold coat pistons
Ported LS7 heads W/ PAC springs and Ferrea exhaust valves
T&D shaft mounted rockers
Cam Motion cam 252/264
Ported FAST 102
Manton pushrods
You have a set of pushrods but no lifters
Still, looking forward to the results. Who ported and machined your LS7 heads for T&D rockers?
Fraser
Old Jul 6, 2015 | 11:09 AM
KiwiKid's Avatar
Hi Millenium,
I was just about to purchase a set of Morel 6132 mechanical lifters for my 400ci big bore/short stroke LS engine when I noticed your post.
It would be greatly appreciated knowing exactly what failed and some sort of basic analysis of the failure mode. Do you also have some photo's you could share because maybe there are some suitably qualified people on this forum, like Kip at Cam Motion etc that could help pin point the problem you had.
Did you call John Callies? He seems like a very approachable and helpful guy with an awful lot of knowledge, least in my opinion.
Cheers,
Mark
Old Jul 6, 2015 | 12:19 PM
chuxdelux's Avatar
Fraser
No pushrods in hand just paid for already. Once I measure for correct length I just need to let Tony know. I had my heads ported by Tony Mamo and my heads machined locally here in Honolulu.
Old Jul 6, 2015 | 12:30 PM
Millenium Z06's Avatar
Originally Posted by KiwiKid
Hi Millenium,
Cheers,
Mark
Something in the body failed, the wheel(s) were good and felt smooth, the lifter bore was good and the outer body was pristine but the lifter wouldn't stay pumped up. It allowed too much lash on a intake valve when running which then mushroomed the Ti intake valve.
The shop and I looked at the lifter, externally it looked fine but my guess is that something was wrong in the piston/inner cylinder and allowed it to leak down too fast. Yes, we called Morel/Callies and were told no warranty. After Morel said no warranty, we took it apart and looked at it but there was nothing obvious.
Initially I was just going to replace the bad pair (link bar models) and move on but since you have to pull the heads to replace lifters I saw no need to risk the other 7 pair being OK to save $700 just to have to possibly spend it and more down the road if they did fail.
We put in a new Ti Valve and the new Lunati lifters with the same push rods and the same LS7 trunnion (replaced the one over the bad lifter) upgraded rockers and the valvetrain is dead quiet (LSL lobes) and 1700 miles later, no issues.
I wont use morel again simply for the warranty aspect, I understand that parts fail, I have a problem with $700 lifters failing and there being no re-course.
Old Jul 6, 2015 | 01:49 PM
Fraser588's Avatar
Good, I would go with the thickest wall Manton offers for 3/8" pushrod. .175"? RIP Terry Manton.
Old Jul 6, 2015 | 01:52 PM
M.BOZZ's Avatar
Well its a good thing that OP is going solid lifters
Old Jul 6, 2015 | 02:02 PM
SHovV's Avatar
Solid FTW. And I had the same issue with one of my stock LS7 lifters during my first HCI build. Pulled it apart to swap parts, pulled the stock lifters out and stored them in a small bucket of fresh oil, stabbed the new cam, put the lifters back in and went to measure for PR length, and for somehow one of the lifters failed.
Anyway, what Manton series are you going with Chux?
I'll be getting series 5 3/8 x .120
Old Jul 6, 2015 | 02:39 PM
chuxdelux's Avatar
Im not sure what series but they will be 3/8 x .95. Do you think I should get the thicker wall .120?
Old Jul 6, 2015 | 02:59 PM
SHovV's Avatar
That's a question for Manton. They suggested series 5 3/8 x 0.95 at first, and once I started talking to them more and telling them what my goals were and what I wanted, i.e., to assemble the most stable valvetrain I could afford, then they suggested the .120 wall 3/8 series 5.
They asked what my valvetrain consisted of, rocker brand / material / type, spring pressures, valve materials, stuff like that.
Also, what I've gotten from talking to many cam and valvetrain experts and companies, you want to put the biggest, stiffest pushrod you have room for and can afford, generally speaking.
Old Jul 6, 2015 | 03:04 PM
  #32
chuxdelux's Avatar
Roger that. I'll look into it. How's your build coming along?
Old Jul 6, 2015 | 03:56 PM
  #33
M.BOZZ's Avatar
I was looking into some 7/16 push rods but haven't called Manton yet. Going with a 8xx lift at 29x duration, was looking to spin around the 8500 rpm range. By the way, sold my set of 5425 so no more pm please
Old Jul 6, 2015 | 04:00 PM
  #34
SHovV's Avatar
Goin pretty good. Hittin the home stretch now. Just need to order headers and pushrods, and a few other small misc. things
Originally Posted by M.BOZZ
I was looking into some 7/16 push rods but haven't called Manton yet. Going with a 8xx lift at 29x duration, was looking to spin around the 8500 rpm range. By the way, the #5425 are off the market
5425 off the market? Who'd you hear that from and what other info do you have about it? Updated design, new part number.....?
Old Jul 6, 2015 | 04:08 PM
  #35
M.BOZZ's Avatar
Sorry about that, No they are still on the market but just sold mine that's all. I will correct my post
Old Jul 6, 2015 | 04:14 PM
  #36
SHovV's Avatar
Oh ok haha
Old Jul 6, 2015 | 04:36 PM
  #37
KiwiKid's Avatar
Thanks Millenium,
Good to hear that there was no obvious mechanical failure with your Morel's, as I am not using a hydraulic lifter, at least I don't have to worry about leak-down etc.
As I am also going with the bushed rollers, I am also eliminating the potential needle roller failure.
Cheers,
Mark.
Old Jul 6, 2015 | 04:52 PM
  #38
Thanks Millenium,
Cheers,
Mark.
Yeah, Id have done the CHE bushed rockers vs the BTR trunnion kit had I seen them in time. Still may go to a HS adjustable LS7 RR but I'll wait and see if I go to a LLSR 1st. As to the Lifters, like I said, no warranty is not ok for me. I'd see what Lunati has for a solid roller or what Cam Motion recommends. This stuff is too expensive to buy twice and manuf not stand behind the product.
Old Jul 6, 2015 | 05:10 PM
  #39
FLYZNTN's Avatar
I have a set of Morel 5206 lifters that are noisy as hell at startup. They quiet down considerably after a couple of minutes and perform just fine but, the loudness at startup would preclude me from recommending the 5206. That said, the OP is running solids so hydraulic woes are irrelevant.
As far as Lunati lifters, I've read on more than one site that they are actually made by Morel......
Old Jul 6, 2015 | 05:13 PM
  #40
Sales@Tick's Avatar
Morel manufactures the Lunati lifters you replaced your Morels with.
