Floating rod orientation?
Old Aug 9, 2015 | 08:19 AM
StolenFox's Avatar
Default Floating rod orientation?
So I've read numerous threads and many contradict each other regarding the floating rods orientation vs the piston dot. After studying the rods at length this morning I "think" I have it figure out but was hoping for definitive confirmation. Here goes:
The big end of the floating rod has two different sides. One side has a larger flat surface and a rough "as cast" chamfer on the face of the rod bearing hole. The other side has a smaller flat surface and its chamfer is machined. In my opinion this means that the smooth machined chamfers face out toward the crank fillets which then presents the large flat surfaces facing inward towards each other. This makes sense as you would want the smooth machined surface facing towards the rotating fillet of the crankshaft and you would want the larger flat surface of the rods facing towards each other as the larger surface area would allow those surfaces to slid past each other with more stability. More "load bearing" surface if you will.
What this means then is that half the rods would be installed with their dimple facing towards the front of the block and half facing towards the back. That's where the contradiction comes in: everything ive read says the rod dimples (not talking about the piston dimple) all face the same direction with some experts saying it matches the piston dot and others saying the opposite.
Can anyone state with 100% certainty the proper orientation?
Thanks!
S.F.
Old Aug 9, 2015 | 10:11 AM
KCS's Avatar
KCS
Moderator
With 100% certainty, I can tell you it doesn't matter. That's why you're reading conflicting statements.
These are on center rods first off, so there's no offset like the older stuff. Secondly, older cranks and afetrmarket cranks have a radius where the journals meet the crank cheeks. This required the bearings and therefore the rods to be orientated such that the chamfer was towards the radius. On a stock LS cranks, there is no radius so it doesn't need the rod to face a certain way to make that chamfer face the radius.
Old Aug 10, 2015 | 07:33 PM
StolenFox's Avatar
Excellent, thank you for clarifying it for me!
S.F.
Old Aug 19, 2015 | 12:47 PM
my bandit's Avatar
What he said ^^ However, for the piece of mind, I oriented all of the bearing tangs to face the pan rail on both sides. That oriented the dot on the rods to face opposite directions depending on the side.
Old Aug 19, 2015 | 05:53 PM
1FastBrick's Avatar
They are on center and it does not matter.
However, From the factory the Dimple/ Dot faces the rear of the block on all 8 rods While the dot on the piston faces forward on all 8 pistons.
The older Press pin LS1 rods, The flat side of all 8 rods face forward to the front of the block.
HTH
Old Jan 5, 2018 | 02:44 PM
DeathByNissan55's Avatar
TIme to wake the dead slightly.
So if i was putting floating rods from a GenIV LQ4 onto a GENIII LQ4 crank, which orientation would I install them?
From what I read it made it sound like the older cranks require you to install in certain matter.
Please let me know,
Old Jan 5, 2018 | 04:12 PM
1FastBrick's Avatar
Please let me know,
The dimple in the middle of the rod faces the rear of the engine.
On the pistons, the dot is forward.
Old Jan 13, 2019 | 07:22 PM
BigEd_72455's Avatar
That was pretty funny. Waking from the dead?? LOL. I found this thread through Google. I have a set of untouched Gen 3 rods and pistons from a 4.8 that I can snap a couple pictures of if you want me to.
its up to you
 Michael S. Palmer
Old Jan 13, 2019 | 07:52 PM
nevermind, I COMPLETELY missed the part about FLOATING in the title.
I think my brain is going on strike, cause it sure as hell don't work like it used to!
Sorry about that.
Old Jan 14, 2019 | 01:26 PM
pantera_efi's Avatar
Default Piston Guided Rod = Floating
HI ALL, yes the above "tech" may be correct, just NOT that the Floating Rod is referenced.
A "floating rod" FLOATS on the crank pin with GREAT side clearance, good for oil flow needed to cool the bearing. (also low friction)
I have assembled LS "race" engines that use a Piston Guided rod, a piston I designed and manufactured by Racetec.
Most often the custom FORGED long stroke crankshaft rod/main fillet is VERY large, good for strength in a crack prone area.
MY piston design (piston guided rod) is ALSO good for strength in the "piston boss" area due it's LIMITED width caused by the placement of my 60-2 (GM58x) wheel.
I use this method ALWAYS with the LS-482, a race engine with a 4.5" stroke crankshaft.
Lance
Old Jan 14, 2019 | 03:37 PM
I believe you meant WRIST pin, not crank pin..
Old Jul 22, 2023 | 02:22 PM
Topfuelstevens's Avatar
Default Rod orientation
Chilton repair manual states the following: the mark on top of the piston and the large tabs(2) on the side of the connecting rod should face the front of the engine.
This is the second reference I’ve read the notates front face direction
Old Jul 22, 2023 | 11:59 PM
Mark (it’s a dot) on the piston top should face the front of the engine, yes. But as far as OEM LS connecting rods go, they can face either way. Although I typically build LS engines with aftermarket rods, I’ve built a few with GM rods and I’ve turned them both directions…ON PURPOSE…to see if it would work out. Those engines are still running today. LS rods are straight-up design (with offset pistons pins) unlike SBC rods that are offset (with a non-offset piston pin), so it doesn’t matter which way the OEM rods face. Now…GM puts the dimples toward the rear at the factory.
Old Jul 23, 2023 | 09:17 AM
01CamaroSSTx's Avatar
Correct me if I'm wrong but the only factory LS rod that I'm aware of that has a rod orientation is the LS7 titanium rods,
