Cammed c6
Old Aug 23, 2015 | 02:56 PM
aAZz's Avatar
Default Cammed c6
So a couple weeks ago. Did a couple of pulls pulley bolt came loose and pulley started wobbling. While it was down threw a cam in there. Still on stock manifolds/exhaust i ordered long tubes and headers so decided not to tune it just yet. Ive been driving it untuned while barely getting on the gas. At first the cel light was on which is normal but tonight while driving noticed the light went off. Is this normal? Cam is mild cam. 227/234. 613. 576 113 lsa
Old Aug 23, 2015 | 05:16 PM
Slickgoat05's Avatar
when my car was first cammed and it was untuned it did the same thing...it was running very rich. don't drive it very much if u don't have to.
Old Aug 24, 2015 | 01:31 AM
aAZz's Avatar
Just wanted to make sure everything was in the norm. Im definately getting it tuned but wanted to install my longtubes and x pipe before i do but it'll probly be a week or so before i get them in as they were just ordered a couple of days ago. Was just trying to avoid having to have it be tuned twice
Old Aug 24, 2015 | 02:39 AM
CAMSTER's Avatar
As you drive it around without getting on the gas you'll be just fine the ECM will adjust it's trims it will however throw all kinds of codes and maybe go into reduce performance mode if you get on it even slightly.
When you disconnect the battery all the trim adjustment will be back to original however.
