Another 370 question
Old Aug 25, 2015 | 03:34 AM
lilaaron233333's Avatar
Default Another 370 question
So I have following for my 370 build
Weisco K398X3 pistons (-3.2cc)
Manley 6.125 rods with arp 2000 bolts
Stock LS2 crank
LY6 block (don't have it yet need to get it)
317 heads
Edelbrock eforce
LS9 gaskets
LEP stage 1 blower cam
ARP main and head studs
With the above set up I have came up with 10:1 cr . I call the machin shop near me an ask for a quote from the to machine the block an assemble the short block. They said that 10:1 cr is a little hi for 6-8lb of boost. I plan on a smaller pulley on the blower an OD ATI damper thay wil put me at around 8-10lb of boost. So my question is should I have gone with a different piston or is 10:1 fine. I read a few 370 post on here an I seen 10:1 t9 being good.
Need some input please.
*** guy at machin shop said the run Mopar motors an 8: and with the 8:1cr your tuning margin is alot bigger then a 10:1 cr motor***
Old Aug 25, 2015 | 08:55 AM
redtan's Avatar
Seems like this machine shop is stuck in the 80s, do they do work on LSx engines or mainly SBCs?
10:1 CR is perfectly fine for 8-10lbs, heck stock engines pushing mid to high 10s CR can run those types of boost levels and tuning is not an issue. And that's on stock pistons and rods.
8:1 CR is way to low and unecessary in today's tuning world. If you were planning 30lbs I would say ok go that low. For a measily 10lbs no need.
Old Aug 25, 2015 | 09:55 AM
Thats what's I figured. there shop doesn't deal with many ls motors. Might jist stay aqay frm them. An forgot to memention I'll be running water meth to. He also said running 6-8lb of boost and a 10:1 motor it will end up being 13:1 :/ ???.what is he talkin bout 13:!?!?!?!?
Old Aug 25, 2015 | 10:12 AM
redtan's Avatar
He seems to be calculating the cylinder pressure of the boost+compression.
If you've got meth injection also then even more so you should be more than safe at those levels. Heck, you can probably push upwards of 17-20 on that setup and be ok.
Old Aug 25, 2015 | 01:47 PM
KCS's Avatar
KCS
Moderator
Weisco K398X3 pistons (-2cc)
Stock LS2 crank
317 heads
Edelbrock eforce
LS9 gaskets
First off, I have those same pistons and they have 3.2cc valve releifs, not 2cc.
Second, he is right about how a lower CR has a wider tuning window, but 8:1 is a bit extreme. The LSA and LS9 factory supercharged engines are both 9.1:1, which would be safer with 10lbs of boost than 10:1.
If you decide to lower the compression ratio, swapping the pistons to an 11cc dish will bring you down to 9.1:1.
Old Aug 25, 2015 | 03:02 PM
So should I go with the -11cc pistons to get 9:1? I though 10:1 was gonna be fine but idk.
Old Aug 25, 2015 | 03:52 PM
KCS's Avatar
KCS
Moderator
I think you should (especially if you don't have a good tuner locally), but others probably won't agree.
Old Aug 25, 2015 | 06:14 PM
I have a good tuner here local.
 Michael S. Palmer
Old Aug 26, 2015 | 07:12 AM
redtan's Avatar
CR also depends on what type of boost you have, and for example your choice of a PD supercharger will nullify some of the downfalls of going with too low of a compression. So you shouldn't feel much of a difference if you go with 9 vs 10 compression, unlike others with say centri superchargers or big turbos.
Old Aug 26, 2015 | 08:39 PM
Here's another question. If in run a lq9 block what has to be done to run it on a 08 tbss. I know side knock sensores need to be drilled an tapped but I have read there's not a chunk of metal on the pass. side to drill and tap so where would that sensor and second will a Gen IV valley cover fit on a lq9? The oil pressure sensor isn't in the cover anymore it's been relocated to the side of the oil pan where the bypass is .
