Pros/Cons Royal Purple
Honestly pretty much any name brand oil will be fine.
Personally I use Castrol Syntec 0w40 which is the "European Formula" made in Germany. It can be found at most parts stores and Wal-Mart here and when it's in an oil change deal is fairly cheap ($32-35 with a good filter and 5 qts).
It's biggest downfall is that it isn't free.
I used Mobil 1 in my Cadillac for a couple reasons:
1) it's what the general recommends,
2) the LY7 high feature V6 went through a lot of oil (even with a drilled pcv tube and a rx catch can), so I needed something that I could find everywhere.
A writer for guns and ammo magazine picks his guns based on whether or not the ammunition can be bought anywhere. He calls it the "Two-dot Test" because of a tiny town in Montana, Two-dot. If you can find the ammo in the gas station/store/post office in a backwoods little town, then you can find it anywhere.
Mobil 1 passes the "Two-dot Test".
RP doesn't burn in my cars and its local to me so I can buy in bulk.
Castrol makes good quality oil, especially the "euro" line of full synthetic.
It just so happens that I use Penzoil Platnum --->> http://www.walmart.com/ip/14958690?reviews_limit=7& .
KW
just pulled a 160k mile motor out of one of the cars and it still looks damn near brand new inside, and that was with quite a few 10k mile oil changes, bearings looked perfect also.
High quality synthetic oil is all pretty much the same. You could get 100 success stories for every manufacturer/brand, and for every success story, you could find someone ranting and raving about how bad that exact product sucks.
Use what you can find easily and afford. Or buy in bulk so you don't have to worry about where it's available.
Wow.
Apparently even Bob the oil guy says the rotella t6 oil is better than royal purple, due to its shear resistance.
I don't know what oil shearing is, but I will Google it later. Probably something really simple like how long it will stretch when poured before it breaks free and forms a drop. But I will look into further.
PS. My phone tries to automatically "correct" the word rotella into foreplay. Lol.
It's the oil's ability to hold up after being crushed... Essentially. In a perfect world, your crankshaft would never touch the rod bearings because of a layer of oil separating them. When the spark plug ignites a cylinder, throwing the piston towards the crank, the upper rod bearing squashes the layer of oil.
An oil with a higher shear point resists being squeezed out more than one with a lower shear point.
They test this by measuring the viscosity of the oil at a set temperature first. Then they pump it through a gigantic diesel fuel injector to really work the oil. And then they measure the viscosity again. The before and after values are compared, and some formula using the two measurements then gives you that oil's shear point.
Not sure if anyone cared for the explanation, but there you go.
And apparently rotella t6 has a more favorable shear point than royal purple.
But yes, any oil with a lot of additives will require you to check your turbo bearings regularly... Probably whenever you change your motor oil.
