799 stock valve spring specs
Old Sep 7, 2015 | 07:21 PM
SMKE EM's Avatar
Default 799 stock valve spring specs
Trying to find the valve spring specs for stock 799 springs
Here's the back story, have a 06 tbss with low oil pressure so I rebuilt a LQ4 shortblock with ls2 rods, 24x crank, and new flat top pistons.
Since ls2 motors came with 243s, and everyone knows 799s are the same head, I found a set of 799s with 20k miles. Purchased them but want to know if the stock springs will handle a stock LS2 cam without floating the valves
I already know stock 243 springs are rated at 560 max lift, but does anyone know the max lift or part # for 799 springs?
Old Sep 7, 2015 | 07:24 PM
SMKE EM's Avatar
Some pics
Attached Thumbnails 799 stock valve spring specs-20150907_185635.jpg   799 stock valve spring specs-20150907_174925.jpg
Old Sep 10, 2015 | 01:14 PM
MuhThugga's Avatar
I'm not sure on those springs. However, a set of yellow beehives are $60 brand new from GM, so I would be apt to change them regardless.
