Comp LS3 timing set
Old Sep 11, 2015 | 10:01 PM
KH504's Avatar
Default Comp LS3 timing set
I'm just getting my LS3 418 running and I screwed up when I ordered my Comp cam timing set. I ordered the one for a LS3 / 58 wheel and its in the car and I now have a po342 code because of it. My question is do you think I can just change the top gear to a factory LS2 gear and leave the Comp lower gear and comp chain? its a single chain setup so I don't see an issue.
Old Sep 12, 2015 | 09:52 PM
S10xGN's Avatar
As long as it's a single chain, prolly so. I've got a Cloyes adjustable set for a 24x that I'll be using on my L92 build, Cloyes tech people said to swap in a GM 4x cam gear...
