383 internals..
Old Sep 22, 2015 | 08:18 AM
Justin Gibbons's Avatar
Default 383 internals..
I have a 383 rotating assembly in my LS1, I was wondering if the crank and rods could be used in an LS3 or any other of the LS blocks?
thanks
Old Sep 22, 2015 | 09:16 AM
KCS's Avatar
KCS
Moderator
Yeah they can.
Old Sep 22, 2015 | 01:28 PM
So there should be no issue using the 4" crank and 6.125" rods? perfect, how many cubic in" would they net me in a 6.2L block?
Old Sep 22, 2015 | 01:57 PM
KCS's Avatar
KCS
Moderator
The LS3 block will be a Gen IV block so there will be some changes to be made to work in a Gen III car. Mostly because of the 24x reluctor and where the cam sensor is located. The PCV system and valley cover will be different too, but you can search all of that for more details. I think there's a sticky on it in this section.
As far as cubic inches, it depends on the bore.
The math is very simple:
Bore x Bore x Stroke x .7854 x 8 = Cubic Inches
