Made a Rookie Mistake. Bought engine without removing heads
My main question is, can a Gen IV Al block be bored out to LS6 specs? Otherwise, I think the cheapest route is for me to just pickup an LS1 shortblock. Unless a junkyard around here has a decent shape Al short block 5.3. I want to keep it cheapish if possible, whichever path I take.
Any thoughts?
That scratch really doesn't look that bad, though. It looks like something got into the chamber and in between the rings/piston. You could probably take it apart, have a machinist bump a bone through it, and reassemble with new rings.
If by some crazy luck they can only been seen and not felt, I wouldn't worry about them. If you can indeed feel them I would have a machinist look at them and see if he can just do a clean up pass as stated by the other guys above.
