LS3 head gasket thickness
Old Nov 11, 2015 | 02:56 PM
JakeFusion's Avatar
Super Hulk Smash
You might see 1-2 degrees more timing (maybe) with tighter quench. Or less prone to detonation in August. I've had builders recommend them. And builders not.
I run them on my current motor. And plan to on the next. But I don't think it's a huge difference.
Old Nov 11, 2015 | 03:47 PM
DavidBoren's Avatar
Every little bit helps. Isn't that the point of changing anything?
Old Nov 13, 2015 | 10:36 PM
KW Baraka's Avatar
Originally Posted by KCS
Lol, I think you overestimate the effect of reducing the quench only .010". If we were talking a 9:1 compressio engine, then maybe, but when the compression is already up around 11:1, it's not really going to do much.......
Mmmmmm.......11:1 scr (or 9:1 scr) won't benifit a whole lot for the optimization of quench.
But if you go to 12+:1 scr, I would say that optimizing quench becomes essential to reducing the likelihood of detonation. With optimized quench, you virtually eliminate detonation as a potential 'problem'.
But hell....what do I know. I've only racked up about 40 passes and 12,000 street miles on my 13.3:1 scr Impala SS.....
Yep.
KW
Old Nov 13, 2015 | 11:04 PM
KCS's Avatar
KCS
Moderator
KW
MIT did tests a long time ago on a bunch of different engines and compression ratios. The effects of reduce quench diminish as the compressio ratio is increase. It's proven.
Old Nov 13, 2015 | 11:06 PM
KCS's Avatar
KCS
Moderator
Maybe in NHRA Pro Stock where teams spend millions to find 5hp, but not in a street car.
Old Nov 16, 2015 | 10:35 AM
DavidBoren's Avatar
I don't believe you.
Lots and lots of non-Pro-Stock cars spending money for 5hp... Everyone from hon-duhs to ZL1's... With everything from cold air intakes to titanium rods/valves... And these are all street cars. You don't have to be a NASCAR driver or an astronaut to appreciate a more optimal setup.
Old Nov 16, 2015 | 11:40 AM
KCS's Avatar
KCS
Moderator
Are you just arguing to argue or are you just so ignorant that you completely miss the point that some "optimization" isn't worth the effort? The quench is already pretty close to "optimal" with the stock gaskets and the piston .004-.007" out of the hole. Dropping it with a .040" gasket isn't really going to do a whole lot. "Every little bit helps," sure, but if you chase every little bit of "optimization" you can end up with a $30k stock bottom end LS3. The price difference between stock LS3 gaskets and Cometic gaskets could be better spent on something like better headers or tires.
Old Nov 16, 2015 | 12:49 PM
DavidBoren's Avatar
If you were in the market for headers, and the price difference between the 1.75" primaries and the 1.875" primaries was the same price difference between the .050" gasket and the .040" gasket, you would gladly pay the extra money for the larger primaries without hesitation. Why?
Because they are better, right? So why not pay the extra money for the better head gaskets? Sure,they don't give you the same results measured on a dyno, but you are paying money for a better, closer to optimal, part. Yes, closer to optimal generally costs more. A better eraser costs more for a kindergartener, too. This is the world we live in.
By the logic of the money could be better spent elsewhere, we all waste all our money that isn't spent on a good turbo kit and an arsenal of spare unmolested 4.8's... Because all that money spent on more optimal displacement, or more optimal rectangle port heads, or more optimal fast intakes is all a waste when we could have bought unopened junkyard motors and better spent our money on exhaust or tires.
Sometimes you have to pay to do it right. But you usually only have to pay once if you do it right the first time.
Old Nov 16, 2015 | 06:41 PM
KCS's Avatar
KCS
Moderator
In this world we live in, we also have budgets too. Not everyone has the budget to buy the ultra badass Jesel steel rockers and .903" keyed solid lifters, so we settle for "less than optimal" stock rockers and LS7 lifters. We have X amount of dollars to invest and want to spend the money wisely in order to produce the best results. In situations such as what the OP described, Cometic head gaskets are just not a wise investment because they may not have any measurable gain at all, no matter how "optimal" you think it is. A better set of headers will almost certainly produce a greater gain to validate it being more "optimal".
Old Nov 17, 2015 | 08:40 AM
DavidBoren's Avatar
I see your point, sir. For sure. I've just never thought that head gaskets, even the closer to optimal ones, weren't going to break the budget one way or another. Stop smoking for a week. Buy one breakfast sandwich instead of two. They aren't THAT much.
Old Nov 17, 2015 | 09:46 AM
KW Baraka's Avatar
I see your point, sir. For sure. I've just never thought that head gaskets, even the closer to optimal ones, weren't going to break the budget one way or another.........They aren't THAT much.
Agreed.
KW
Old Nov 17, 2015 | 10:44 AM
  #32
KCS's Avatar
KCS
Moderator
No, that alone won't but it all adds up. An extra $100 here and there by themselves isn't much, but by the time the engine is built and running, you could be thousands of dollars over your original budget. Happens all the time and will sometimes kill a project completely. I'm a victim of it too lol.
All I'm saying is if you're on a budget, there are better things to spend your money on. If you're throwing down on a high dollar build, by all means do what makes you happy.
Old Nov 17, 2015 | 10:51 AM
  #33
KW Baraka's Avatar
.....you could be thousands of dollars over your original budget. Happens all the time and will sometimes kill a project completely. I'm a victim of it too lol.......
We all do that on our first (and second.....and third....) builds
.....All I'm saying is if you're on a budget, there are better things to spend your money on. If you're throwing down on a high dollar build, by all means do what makes you happy.
We can agree to disagree ....... I mean, I look at optimized quench as much as an insurance policy for my 'high dollar build", as anything else. A matter of perspective, I supposed.
KW
Old Nov 17, 2015 | 11:18 AM
  #34
KCS's Avatar
KCS
Moderator
KW
100% agree. It's almost completely subjective. I get to build and machine my own stuff so I can cut the deck to optimize quench. Unless I need to run a cometic, GM gaskets till I die!! Haha
