Hydrolocked LS3 bent rod and broken piston
Old Nov 10, 2015 | 05:00 PM
casias's Avatar
Default Hydrolocked LS3 bent rod and broken piston
I bought this LS3 from a 2014 SS with 14k miles. It sucked water into the intake, bent one rod and broke the piston.
I am looking for options.
I am planning on running an LSA supercharger with stock pulley, in an AWD application. Vehicle will weigh about 4000 lbs.
Should I
1) replace the rod and piston, and put it back together?
2) replace the piston and upgrade the rods
3) upgrade pistons and rods
Old Nov 10, 2015 | 05:17 PM
DietCoke's Avatar
ls3 rods are as strong as the crank. i'd just throw a new piston in it and let her rip.
Old Nov 10, 2015 | 05:21 PM
DavidBoren's Avatar
I know that the genIV stuff is pretty strong, but I would probably go forged just for the peace of mind. Pretty sure you can find LSA rods and pistons for a song and dance.
Old Nov 10, 2015 | 05:26 PM
casias's Avatar
I have been looking for lsa rods and pistons. Can't find a set used. Anyone know where a set might be?
Old Nov 10, 2015 | 05:59 PM
DavidBoren's Avatar
Pace performance has the lsa rods, p/n 12604857, for $35 a pop... Are you going to really save that much buying them used?
There's a plethora of forged pistons for relatively cheap.
And even the lsa uses hyper pistons, not forged. A bad tune/detonation will kill a forged piston just as easily as it will kill a hyper piston.
Old Nov 10, 2015 | 08:48 PM
DietCoke's Avatar
LSA rods are the same as LS3 rods. Powdered metal (not forged).
Old Nov 11, 2015 | 07:02 AM
casias's Avatar
Not sure if you are saying I should use forged aftermarket, or lsa hypereutectic. The reason for the LSA pistons would be lower compression.
As for part numbers.
Does anyone know why the SS engine I have shows part number 12649190 for $105 on gmpartsdirect, and the zl1 and cts-v show 12604857 for $30?
I know the ls3 non-supercharged and LSA supercharged rods are different, but the price difference is weird.
Old Nov 11, 2015 | 08:01 AM
redtan's Avatar
Pretty sure I saw a post somewhere showing that there are indeed differences between those two (even though as you said both are powdered metal).
Old Nov 11, 2015 | 08:52 AM
DietCoke's Avatar
There might be a difference visually, but neither is stronger then the other. They're both (very large and stout) PM rods.
Old Nov 11, 2015 | 09:10 AM
KCS's Avatar
KCS
Moderator
You're right that they're both powdered metal, but the LSA rods are definetly larger, heavier, and stronger.
Old Nov 11, 2015 | 09:17 AM
farmington's Avatar
replace it with the exact rod and piston or balance could be affected.
Old Nov 11, 2015 | 09:20 AM
casias's Avatar
Yeah. I think after reviewing my options, and what I want to do with this, I think I will replace the one piston and rod with the original, and put it back together. LS3 engines do well with 6-7 psi boost and proper tuning. I am not looking to make more than stock LSA power anyway.
Old Nov 11, 2015 | 09:40 AM
A.R. Shale Targa's Avatar
Have a local shop perform two machining steps to the seven used rods as well as the one new one you purchase
All the pin bushings should be honed from .0004" wrist pin clearance to .0008"-.001" range
Also the big ends should get torqued with oil on the threads and EPL. Extreme pressure lubricant (dark grease) under the bolt head; and then receive just a few honing licks on the Sunnen rod machine. If done correctly, they will still be within size limits, have adacuete bearing crush, and most importantly will be round. It's really weird but true how the factory rods/bolts just do not repeat on size/roundness when retorqued. I've seen this on L33 stuff; LQ stuff; and my own LS3 rods
Out of round Rod big ends will murder new bearings and usually end with **** hanging out of the block. Check. Check. And re check everything
Old Nov 11, 2015 | 11:39 AM
DavidBoren's Avatar
I will second the motion for getting factory rods blueprinted and balanced.
I have read about the oem rods not returning to round in arp rod bolt discussions, as well as discussions pertaining to reusing oem bearings... So it would probably behoove you to take the extra steps to ensure that all the rods are the same, and are all correct.
It's always cheaper to do it right the first time.
Old Nov 11, 2015 | 05:45 PM
casias's Avatar
OK. Thanks for the advice.
Old Nov 25, 2015 | 12:22 PM
Luke Mages's Avatar
guys on the g8 boards have been running at 700hp+ for years with no issues with the rods. My g8 is daily driven with 9psi at 550whp without any issues.
Old Nov 25, 2015 | 03:58 PM
Know It All's Avatar
The problem is when the motor is hydrolocked. Then even the forged stuff will bend like a paper clip.
Old Nov 26, 2015 | 08:17 AM
hrlyhnx's Avatar
I would re hone the block and put in new internals if the engine is out of the car and half the engine is apart. peace of mind and cost effectiveness are the two reasons why I would just freshen up the short block with new internals and machine work.
IF you have another car to drive to work and the Walmart then slow your roll do it once, do it right! 6-7 lbs of boost is only good until the guy next to you whoopz your *** at the light! then it goes to 10-12, *** kicked again THEN ITS ****!!!!!!!!! I SHOULD OF FORGED WHEN THE BLOCK WAS OUT LAST YEAR!!!!! LOL
Old Nov 26, 2015 | 08:42 AM
Any idea on the weight differences ?? The Katech take out LS3 rods I ended up with were IIRC 665 grams total so I'm just curious if these would have been from an LSA engine
Old Nov 26, 2015 | 08:53 AM
KCS's Avatar
KCS
Moderator
I didn't get a chance to weigh the last set I had in my hands. They seemed to have a thicker beam and more material around the pin end which was tapered kind of like an LS7 rod. Here's a pic I found:
