crank bolt arp
Old Dec 7, 2015 | 06:17 PM
cals racing ss's Avatar
Angry crank bolt arp
does this bolt have oil pressor behind it ? no oil on out side of seal oil is porring out the bolt was finger tight does not look like it move much or at all ati system can anybodytell me if oil pressor is at the bolt or is it a bad seal ? or just backed off thinks guys cal's
Old Dec 7, 2015 | 09:14 PM
S10xGN's Avatar
Threads in the crank are blind, no oil pressure...
Old Dec 8, 2015 | 11:36 AM
Unertl42's Avatar
Please learn how to type and formulate a sentence, as it is very hard to understand exactly what is going on with your car. A lot of us are here to help. A picture would be very helpful at this point.
Old Dec 8, 2015 | 08:09 PM
agoins's Avatar
Do you have an aftermarket crank? Does your crank have a keyway for a balancer in it?
If so its probably leaking between the crank and harmonic balancer looking like it is the bolt leaking. There should have been silicone put in that keyway if you have one.
EDIT: you have an ATI balancer, take out the bolt and put silicone in the keyway slot that should seal your leak up.
Old Dec 9, 2015 | 03:52 PM
Gray86hatch's Avatar
Silicone on both sides of the washer.
Tim
