LS2 to LS1 swap question
Having some compatibility issues with the Timing gear. I need to use the LS2 gear since it has the sensor bosses on the face. Problem is that gear has different mounting holes and sits at a different depth on the crank shaft and a center through hole mount vs. the gear on the LS1 which has 3 mounting holes. Does anyone know if I can buy a conversion gear that mounts and sits in the correct position in the 5.7 LS1 but has the sensor bosses for the LS2 6.0?
Having some compatibility issues with the Timing gear. I need to use the LS2 gear since it has the sensor bosses on the face. Problem is that gear has different mounting holes, center through hole mount vs. the gear on the LS1 which has 3 mounting holes. Does anyone know if I can buy a conversion gear that mounts and sits in the correct position in the 5.7 LS1 but has the sensor bosses for the LS2 6.0?
Andrew
