LY6 max effort cam help.
Old Jan 7, 2016 | 06:57 AM
YMEOFCR's Avatar
Default LY6 max effort cam help.
I have an 84 Monte Carlo with a stock bottom end with katech rod bolts and the factory truck intake. The car gas long tube headers, 4k stall converter, 3.89 gears. Im looking for a max effort cam and think i have it narrowed down to 2 unless someone knows of another one. Im wondering which you would choose and why.
Choice #1
http://store.cammotion.com/titan-kin...-port-camshaft
Choice #2
http://www.briantooleyracing.com/nat...-camshaft.html
Old Jan 7, 2016 | 10:23 AM
KW Baraka's Avatar
Originally Posted by YMEOFCR
I have an 84 Monte Carlo with.....
Not much difference in these cams....seems the BT cam would have a bit more overlap (but only about 2*) which would ordinarily mean it'll have a stronger top end. That 2* ain't much but it could be worth maybe 5-10 HP, all on the top end.
The BT cam is $60 less as well.
KW
Old Jan 19, 2016 | 03:52 PM
Sales@Tick's Avatar
Don't forget to give this cam some consideration.
http://www.tickperformance.com/tick-...3-l99-engines/
Old Jan 21, 2016 | 02:52 PM
dogsballs's Avatar
The factory gm lsx454 cam also works well with 1.7 rockers 236/246 615/615 112(110).
Can be found dirt cheap when dudes yank
