L76 Rod Bolt Torque specs and procedure?
Old Feb 1, 2016 | 01:40 PM
ringgold's Avatar
Default L76 Rod Bolt Torque specs and procedure?
Want to verify the specs and procedures for torquing OEM rod bolts for the L76 6.0 engine. What I have found is this:
First Pass20 N.m (15 lb ft) Connecting Rod Bolts - Final Pass 85 degrees
Is this correct?
Old Feb 1, 2016 | 07:19 PM
Russ K's Avatar
Is this correct?
Yes that is correct as per ALLDATA
Russ Kemp
Old Feb 1, 2016 | 08:32 PM
ringgold's Avatar
Russ Kemp
Thank you sir. Reason I asked this question is because the rod bolts on these rods do not have the dimples or anything like the repair manual I have says they may have. They have some lettering and numbers on them I think. I'd take a pic, but don't have one beside me right now.
