Need help to i.d this Ring,poss Engine Scam
Old Feb 17, 2016 | 06:59 AM
Scott Robertson's Avatar
Default Need help to i.d this Ring,poss Engine Scam
Hi Guys,
I know it's a long shot but my friend just paid AU$20k for a LS3 rebuild and have been told by the builder 3 different ring types fitted to his Motor.
He requested Gapless Rings but the Invoice says CP Rings then on next page says Hastings Rings ,then the Builder staes he put Filebacks in it
So where all a bit confused and was hoping someone spots the "N030" and could really help sort this out. Cheers
First post but have been up and down this Forum gaining so much helpful info so a big thank you to all.
I'm looking for the manufacturer of the Piston Ring I removed from a LS3 it has "N030" printed on the top right hand side near the gap.
I can post a photo latet if helps. Thanks in advance. Scott
Old Feb 17, 2016 | 05:21 PM
KCS's Avatar
KCS
Moderator
I've seen that NO30 before, I think it's Total Seal but I'm not 100% sure about that.
Old Feb 17, 2016 | 05:33 PM
machinistone's Avatar
I'd rather see the face of the ring head on than a light reflecting top shot, but based on that picture it looks like the NPR gas nitrided steel top ring that many manufacturers are offering these days under their own cute names.
He's better off without gapless rings unless it's an alcohol motor, and that's only because it helps with limiting fuel dilution of the oil.
