Another pushrod question
Old Feb 27, 2016 | 12:24 AM
gareth12's Avatar
Default Another pushrod question
Hey all, just hoping for some confirmation on my pushrod choice
L92/comp camps 281LRR HR13 (231/247 .624 113)/.050 decked off the heads/lunati tie bar lifters
I bought 7.350 pushrods at a guess, i think they are too long. I have just done a zero lash check, i get 7.255 so i think 7.300 would be ideal given they require .045-.050 preload.
The only thing that has me second guessing myself is that when the pushrod starts to preload it seems to do so very easily for a little but and then gets significantly harder to depress. I have done my measurement with zero preload and im just making sure i shouldn't be taking up that initial slack
Also what would be the possible consequences of running the 7.350 pushrods, even if just for a while?
Thanks
Old Feb 27, 2016 | 08:36 AM
140K_GXP's Avatar
Going off what you stated for your needed preload, you will be risking lifter failure and accelerated wear on your cam with too much preload.
Old Apr 29, 2016 | 10:58 PM
Yasei's Avatar
Yeah, way too much preload for those lifters. Don't run it. Lunati/Morel lifters are recommended 0.02-0.04" preload, so aim for 0.03".
