LS9 Valves
Old Mar 20, 2016 | 11:47 AM
collins8's Avatar
Default LS9 Valves
I am having a set of LSA Heads ported for my ZL1 and was wondering if anyone knew of a good place to get a good deal on the LS9 valves, new or used?
Rob
Old Mar 20, 2016 | 01:31 PM
gnx7's Avatar
Just buy some LS9 heads and sell yours.
Ti valves are about $800/set
Old Mar 23, 2016 | 01:23 PM
yonerhottlt1's Avatar
Don't you have to get the block machined or use some kinda shim/spacer kit to run those?!
Old Mar 23, 2016 | 03:14 PM
DavidBoren's Avatar
I think gnx7 nailed it. The cnc ls9 heads run about $1800 and come with the valves you want.
And no, you do not have to notch the block. I don't know about spacers or shims, but the titanium valves require lash caps, if that is what you are referring to.
