hollew stem valve question
Old Apr 2, 2016 | 10:57 AM
tom70's Avatar
Default hollew stem valve question
plan on buying a set of gm performance cnc 821 heads. will hollow stem intake valves hold up to drag racing?
Old Apr 2, 2016 | 12:24 PM
KCS's Avatar
KCS
Moderator
Yep, lots of drage race combos have been run successfully with them. I'd be hesitant with a big solid roller and lots of spring pressure though.
Old Apr 2, 2016 | 01:25 PM
tom70's Avatar
.622 lift with btr .650 duel springs
Old Apr 2, 2016 | 04:31 PM
HighspeedLean's Avatar
.637 lift, 250 passes old BTR springs, and as of late, 7800-8000rpm in the lights. (Note to self:I should check the spring pressure one of these days.) If, for some reason I should need another set of intakes, these will be bought again.
