Anyone here using a TSP 225/230 ?
I have been recommended a TSP 225/230 .629"/.615" 111 for my lq4 build. It has l92 heads, standard transmission. Heads will be milled .015". Intake will be a victor JR carb'd with a 750. Gonna try and go 1 7/8 headers. Going in a 3300ish lb 73 camaro. Any reviews on this cam ? It was recommended to me by texas speed and I just want to confirm with other users that this setup will work, more opinions cant hurt. I want a street and strip cam and dont mind a lumpier idle. Cheers
Call Martin Smallwood... he IS an expert (possibly THE expert) on cams.
If you get a TSP camshaft you also get a camshaft built on a top $ camshaft core & cnc machined to your exact specs.
No worrying about camshaft peeling, camshaft squealing etc!
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
