Questions on Lsa block
Old May 1, 2016 | 12:15 PM
KCS's Avatar
KCS
Moderator
Originally Posted by booboo37
What about a Ls7 block ?? I think the biggest i seen was 442ci. ...i think....i wonder if guys ever make a 455ci.. with the Ls7 block and 4.250 stroke....??
HKE built a 4.125" x 4.250" (454ci) LS7 years ago, strictly NA since the piston ends up being really short. They were custom too, not an off the shelf part.
Old May 1, 2016 | 03:44 PM
booboo37's Avatar
KCS......you built a 440 with a Lq9 block and used a 4.250 crank ??
Old May 1, 2016 | 09:20 PM
KCS's Avatar
KCS
Moderator
It's not done yet. I'm going to try to have the shortblock assembled by this weekend before moving on to the valvetrain.
Old May 1, 2016 | 10:09 PM
booboo37's Avatar
Wow i didn't think that would be safe with that block.......How deep is the cylinder on that block ??
I might be buying a Ls7 block next week and they have a 5.800 inch deep cylinder and was thinking of going to a 4.125 stroke crank.....but if 4.250 is safe then i might do that..
Old May 1, 2016 | 10:12 PM
booboo37's Avatar
I found this chart but don't see your block...
Attached Thumbnails Questions on Lsa block-screenshot-www.erlperformance.com-2016-04-15-11-54-50_zpsguyxxkyx.jpg
Old May 2, 2016 | 07:01 AM
KCS's Avatar
KCS
Moderator
The cylinders are a little over 5.5" long. I think they're the shortest of all the LS blocks.
Putting a 4.250" crank in a standard deck block isn't a simple task. You're going to have to use custom pistons as no one to my knowledge makes a shelf piston for this yet. You're going to have to clearance the bottom of the cylinders for the rod bolts and you're most likely going to have to use a smaller base circle cam.
