Lsx engine builder that does piston squirters??looking for one?
Old Apr 28, 2016 | 02:15 PM
bmf5150's Avatar
Default Lsx engine builder that does piston squirters??looking for one?
I'm looking to build a lsx427 and I want to add piston squirters to the shortblock..you guy know of any engine builders who does them in there shortblocks?
Old Apr 29, 2016 | 10:42 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
BMF
If you are going to use the LSX Iron block, the block itself does not have provisions for oil squirters. If you are wanting someone to custom drill the LSX for oil squirters, that is a different story. It is possible for it to be done, but I don't know of any shop that has the capability to do it.
The only option that comes to mind is ERL. Try there.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old May 3, 2016 | 02:06 AM
bmf5150's Avatar
Originally Posted by Sales2@Texas-speed
BMF
Thanks I'll talk to erl
Old May 4, 2016 | 08:33 AM
Jdseeling's Avatar
In my experience putting together a Supercharged LS for my 68 Pro-Touring Camaro....I spoke to Brian Thomson of Thomson automotive. He has designed his on piston squirter system that is proven in supercharger and turbo charge applications. He builds all of Mark Steilow's 950+ HP motors with his piston squirter design. He has done them in both LS7 and LSX blocks. I believe any block can be machined to fit the RHS piston squirters too, I looked into all of the options. Talk with Brian, wealth of knowledge.
Old May 4, 2016 | 10:58 AM
skimms98's Avatar
Katech
Old May 4, 2016 | 01:29 PM
Katech_Jason's Avatar
LS1TECH Sponsor
BMF
We can add piston squirters to the following blocks:
LS2
LS3
LS7
L76
L92
L99
LSX
LT1 (Gen 5)
LT4 (Gen 5)
L86 (Gen 5)
L83 (Gen 5)
Old May 5, 2016 | 12:21 AM
bmf5150's Avatar
Hey Jason,what's your email??im looking to build a lsx427 with piston squirters
LS2
LS3
LS7
L76
L92
L99
LSX
LT1 (Gen 5)
LT4 (Gen 5)
L86 (Gen 5)
L83 (Gen 5)
Old May 5, 2016 | 12:22 AM
bmf5150's Avatar
Brian builds killer motors!!
Old May 5, 2016 | 07:05 AM
LS1TECH Sponsor
jason@katechengines.com
Old May 6, 2016 | 04:31 PM
DavidBoren's Avatar
A little shop, called Bo Laws Performance, makes (or made?) jigs that bolt in place of the main caps and allow you to drill LS blocks for oil squirters. Not sure if he has anything for the LSX blocks, though. From the research I put into it a while ago, most people who use the Bo Laws jigs end up installing BMW check-valve oil squirters.
Old May 16, 2016 | 01:50 AM
bmf5150's Avatar
Thanks
Old May 18, 2016 | 08:57 PM
gnx7's Avatar
Steve Demirjian at RED can do machine work like that also. Get some quotes from a few places and then decide.
