Instruction sheet for degreeing a cam
Old May 22, 2016 | 10:27 AM
mr08353's Avatar
Default Instruction sheet for degreeing a cam
Does anybody have the instructions for degreeing a cam with the heads off? I am installing new cam in LS3 and have the Comp Cams degree wheel kit 249-4294. Only instructions are for performing with heads installed. I want to complete it with the "heads off". If anybody has the instructions or can walk me through it here, that would be great. I was able to determine crank TDC with the wheel, but then what? I've checked YouTube and nothing there. (Unless I missed something) been searching for a while. Plz & Thx.
Old May 22, 2016 | 10:49 AM
KCS's Avatar
KCS
Moderator
It's the same as with the heads on, you're just measuring directly off the lobe or lifter.
Double chck your PN, did you mean 4942?
Old May 22, 2016 | 12:15 PM
mr08353's Avatar
Yes I did. Thanks. Dislexia kicked in I guess.
