L92 burning oil at an excessive rate.
The engine runs and drives great but is going through a quart of oil every 500 miles.
Do the L92/L99/LS3 engines have a problem with rings?
Only drain about a tea spoon of oil out of the catch can
Has any one had a issue of oil leaking into the intake/exhaust ports from where the bolt holes for the rocker arm bolts were hit during porting?
hopefully the valve guides where checked and valve stem seals were replaced when the heads were done.
Hopefully its something simple but if it isn't this just gives me a reason to build a stroker motor
