500 rwhp Gto recipe
Best time ive seen after scouring the internet for hours is an 11.131, feel free to inform me of any faster ET's so i can set my goals accordingly.
Stock is currently stock (excluding a volant cai, 3'' catback and tune) But I'm going to be starting the build with the headers some time this week, heres my shopping list so far
Pacesetter lt's with catless mids
232/232 112lsa .600/.600 lift
ls3 heads? Open to suggestions but no CNC ported $2000 monsters
FAST 92mm intake
3.91 gears
15'' weld rims with non dot legal radials for the track, looking at nt555's or super sports for daily driving.
Car will still be a daily, so low end torque is still a consideration along with no insane weight reduction ie removing speakers and carpet, but will have weight reduction such as spare tire passenger/rear seats etc for when i head to the strip. Looking for a 3600 race weight. Any real life experience with a similar combo or thoughts? Would that engine combo give me 500rwhp, would the cam maintain driveability, and could this hit 10's all motor?
Well they were on the car when I got them so I have nothing to compare them to, but they seem to get the job done just fine. I would however not recommend the Pacesetter y-pipe UNLESS you have a better merge spliced in...which is exactly what I did. Their merge is absolutely horrible lol
If this is your daily, then I would suggest abandoning the first two goals and modify with the third goal in mind. It will be a much more enjoyable experience.
- Brian Tooley hand worked TFS 220cc heads (11.5:1 compression)
- Brian Tooley custom spec'd cam or his stage 4 cam
- Brian Tooley port matched FAST 102mm intake with a 102mm TB (Nick Williams, Warr Performance, etc.
- 1 7/8" long tube headers
- 3" dual exhaust
- And you'll want to get a good street/dyno tune
FAST 92mm intake
3.91 gears
Car will still be a daily, so low end torque is still a consideration.....
As far as heads go......you can have Texas Speed CNC ported OEM LS3 heads for $1300 (they create positive flow to .650")....and TSP will install .660" PRC or PAC springs for about $240 more.
http://www.texas-speed.com/p-1179-pr...ted-heads.aspx
BTW....with that cam, I have a set of NIB CompCams Ultra Pro-magnum rockers that would bring your lift to about .635", if you're interested.
. That having been said, the cam you're looking at is an equal split cam. If you're dead set on LS3 heads and a 232 intake duration, you may be better served with a cam with something like 240* duration on the exhaust lobes. More overlap, a bit less driveabilty, but would gain you another 10 - 15HP (or so) to the wheels....most gains coming above 5K RPMs.
What kind of compression? That much cam REALLY needs 11.3 to 11.5:1 static compression or it won't perform as it should.....
KW
Last edited by KW Baraka; Jun 6, 2016 at 11:24 AM. Reason: Added Content & Misspellings
Don't know about hitting 10's.....but that cam will only have about 8 or 9 degrees of overlap. Yeah....it'll romp a bit, but it will be VERY 'drivable'
KW
KW
Thanks for all the replys so far! I should have the 3.91's installed sometime in the next two weeks and the pacesetters this weekend, going to head down to the track this friday to see if i can get some et's stock to see my gains from just the 3.91's and headers.
You think a 240 cam is excessive and want an operating range of 2k to 6.7k, but then you still want to make 500rwhp. No cam making 500rwhp is going to be in it's operating range at 2000. Hell, you'd want something in the mid to high teens as far as duration if you want any noticeable grunt at 2000.
I think you can achieve your goals as far as low 11s N/A, but it's going to take a good amount of weight reduction, properly setup drivetrain and suspension and a killer driver. Stop worrying about power and just go with proven combos and let the dyno read whatever it wants to read.
